November 23, 2024, 10:01:20 am *
Author Topic: 3 Way Fridge Instructions.  (Read 32237 times)
Nobby Diesel
« on: June 05, 2008, 10:38:33 am »
I've got one of these 3 way fridges. Being a true "bloke" who doesn't need the instructions, I threw them away when I bought the fridge a couple of years ago.
Now, having never tried to run it on gas, I'm scuppered. I can't seem to get it to work.
Does anyone have any ideas?
It's a Combi Cool absorption fridge, 40 Ltres capacity approx.
Thanks.
If you can't fix it with a hammer, you have an electrical problem.
Rusty
« Reply #1 on: June 05, 2008, 11:05:30 am »
You've got mail mate.
Rusty
The Brethren Rock
Maximum
Mad Max DFH
« Reply #2 on: June 05, 2008, 11:22:11 am »
Most caravans use for the gas heater 2 aa batary's for ignition.
Maybay its the same with coolers.
Check for 2 penlites
Live life to the Max
« Reply #3 on: June 05, 2008, 12:25:15 pm »
We've got a Combicool - my recollection is that you mustn't touch the controls for the electric when you've got it on gas as that cuts the gas off.  So you turn it to gas and then leave it alone!
Lighting can be tricky, the auto ignition is a bit flakey on mine, I'd recommend sticking a long match through the lighting hole at the bottom!
Also, if you've not run it on gas for a while, I'd turn it upside down overnight and let it all settle before turning it back up again - not sure what it does but it works!
Also make sure its level when you run it, our first one wasn't very sensitive but the second one needs to be really flat before it works.
« Reply #4 on: June 05, 2008, 12:39:56 pm »
What's the actual problem, Nobby??
Does the gas jet light OK, but the fridge still doesn't work, or can't you get it to light?
If the former, and it works OK on electric, it's probably the thermocouple.  If the latter, don't forget you have to hold the gas button down when you light it, and hold it down for 10-15 seconds after you light it to warm up the flame-failure device.
If it works OK on electricity, there's no point in inverting it (sorry Anita) - the refrigeration plant is the same for all 3 modes - only the heat source changes.
If all else fails, you'll have to pitch near me and borrow some amps from the genny.
Nobby Diesel
« Reply #5 on: June 05, 2008, 02:47:07 pm »
Del,
It's just a problem with getting the gas ignition working. I've been given a few pointers now, so phase 2 will commence tonight, after work.
Thanks.
« Reply #6 on: June 05, 2008, 03:18:40 pm »
It's quite difficult to tell if it is lit.  If you put your hand over the outlet at the top of the fridge (at the top of the ignition bit) you should feel a bit of heat, but the fridge is virtually silent.  We've spent ages thinking it's not lit to discover that it was lit all along!
wishy
Shed's do track days!!!!!
« Reply #7 on: June 05, 2008, 07:02:26 pm »
Hi Nobby,
One other thing.........if you get the pilot light working and it still does not cool......
Turn the fridge upside down for a few minutes,upright and the try again.Being an absorbtion fridge the refridgerant is ammonia crystals, and sometimes they solidify ,therefore by turning upside down breaks up the crystals and redistributes onto the heater.
The other thing with absorbtion fridges is that they have to be perfectly level in use otherwise they won't work efficently.
Wishy
Brake Later
« Reply #8 on: June 06, 2008, 07:25:49 am »
Hi Nobby,
Wishy
That works for the combi cool last year at LM it lit but did not cool so we emptied it turn it upside down for a hour or two the put it the right way up (we have fitted a spirit level in the control panel to get ours level) lit it and hay presto cold beer working fine....
Oh one thing to remember with the Combi cool version is the gas part will not work if the thermostat for the elastictricery part is set to anything other than off! And don't ever set the gas thermostat to High only go to 3/4 max cold....
« Last Edit: June 06, 2008, 07:28:47 am by Brake Later » Logged
« Reply #9 on: June 06, 2008, 12:34:01 pm »
Del,
Thanks.
Any luck with the fridge, Nobby??
Lazy B'stard
« Reply #10 on: June 06, 2008, 02:13:16 pm »
We've had bother with those damn things in the past, they seem to respond well to a right good kicking from a few hot and thirsty blokes.  Another problem is capacity- the beer is never in long enough to cool properly.
 Last year we fitted a huge truck battery and a 2000w invertor in the van and took a chest freezer which we got down to temp before leaving. Result- gallons of ice cold beer and poo for everyone!
The Wise One
I'm a CA Goddess!
« Reply #11 on: June 06, 2008, 02:22:27 pm »
I was just been thinking we havent had the "How to keep your beer cold" thread yet this year!!
Have we all become so sophisticated that no-one digs a pit and uses the wet cloth, condensation and convection method any more?
 Grin
« Reply #12 on: June 06, 2008, 02:33:30 pm »
 Grin
You on about the free love again, Fran??  Cool
The Cheeky Northern Monkey
« Reply #13 on: June 06, 2008, 02:42:52 pm »
well a thread on keeping beer cool would come in handy as i wont have a fridge or anything to keep mine cool so any help will be great Smiley
DeanoX
« Reply #14 on: June 06, 2008, 03:06:20 pm »
Was looking at those 3-way fridges for family camping later in the year ...are they worth the dosh ?
