its a Apexi RSM ( but already mounted in the mk3 astra ashtray )
- this can be removed with no problems
bought this the other week off a lad on MIGWEB but i may have a change of plans so may not be needed
handy piece of kit really
this is it in short -
The APEXi RSM is a complete multi function measuring device designed to measure and monitor data such as vehicle speed, engine RPM, and elapsed times. You can enhance it's functionality by use of the optional G-Sensor which will allow the calculation of power and torque based on vehicle weight and rate of acceleration as well and pitch and roll G.
Like the original, the new Rev / Speed Meter GP is a complete multi function measuring device designed to measure and monitor data such as vehicle speed, engine RPM and elapsed times. The new screen utilizes the easy to read VFD (Vacuum Flourescent Display) with built in light sensor used in many of APEXis line up.
The new unit also delivers a host of new functions.
Standard features include:
* Engine RPM
* Vehicle Speed
* Travel Distance
* Battery Voltage (all which can be displayed in real-time graph mode, or analogue mode; 1-4 channels at a time)
* Peak Hold
* Replay (60secs)
* Speed Limiter Cut
* 0-100m/200m/400m time with Trap Speed
* 0-100km/h/200km/h/300km/h times
* Mid Range Acceleration (user can preset any range of speed to measure)
* Stop Watch functions
* Best Time Memory
* RPM Warning
* Speed Warning
* RPM & Speed Outputs (for external devices requiring an RPM or Speed signal)
* Tyre Size Correction (for timing accuracy)
* Vehicle weight input.
and a small Vid -
a small clip of the Apexi
im after what i paid inc delivered -
£80 delivered to your doorlet me know -
mintsauce005@hotmail.comKev
