November 22, 2024, 10:25:25 pm *
Author Topic: I've put a USB memory stick through the washing machine ::)  (Read 2221 times)
« on: January 26, 2008, 11:16:23 pm »
Should I use it at home, or maybe try it in one of the work PCs?
Tit!!
« Reply #1 on: January 26, 2008, 11:37:01 pm »
Leave it for 24 hours until it is dry and then it will be fine. Electronics are only damaged if power is applied when they are wet.
The odds of you damaging the PC are very low, The USB drive will blow up first.
« Last Edit: January 26, 2008, 11:39:18 pm by Rick Cutler » Logged
« Reply #2 on: January 27, 2008, 12:12:18 am »
Agree - leave it to dry out. The longer the better.
The only good/bad bit is putting it thru the washing machine, is its cleanned up all those dirty sites!  Grin
