« on: November 16, 2006, 04:54:06 am » |
This will drive you nuts!! The object of the game is to move the red block around without getting hit by the blue blocks or touching the black walls. If you can go longer than 18 seconds you are phenomenal. The US Air Force uses this for fighter pilots. They are expected to go for at least 2 minutes. Give it a try but be careful...it is addictive!! The URL is http://tinyurl.com/56t9u
« Reply #1 on: November 16, 2006, 04:57:19 am » |
Hi, I too have friends with nothing better to do than play on the internet. Incase you are wondering. I took 5 tries just to get past fractions of a second. 8.3 seconds on the 10th attempt. Phil
Nobby Diesel
« Reply #2 on: November 16, 2006, 11:17:38 am » |
WOOWWWW.
12.83!
Does that make me a fighter pilot?
If you can't fix it with a hammer, you have an electrical problem.
« Reply #3 on: November 16, 2006, 12:17:26 pm » |
No you are 107.17 seconds short, so you are dead in skies!
Doris
« Reply #4 on: November 16, 2006, 12:27:49 pm » |
I'm phenomenal! 18.765 seconds.
Bob U
« Reply #5 on: November 16, 2006, 12:33:01 pm » |
35 minutes and can't do more than 8 seconds.
Have you met my fellow pilots?
There is a corner of a foreign field that will be forever England ------ Houx Annexe And the bastards have built on it.
garyfrogeye
« Reply #6 on: November 16, 2006, 01:02:09 pm » |
17.532 seconds but most of my other efforts were less than 1 second. I've stopped befor I kick the screen in.
TonyT
« Reply #7 on: November 16, 2006, 01:42:08 pm » |
A tad over 12 seconds.
oldtimer
« Reply #8 on: November 16, 2006, 02:00:16 pm » |
Blimey that is fun! Never been phenomenal at anything like that before... 3rd go 55.267 seconds. Giving up now until somebody beats it.
garyfrogeye
« Reply #10 on: November 16, 2006, 02:13:21 pm » |
Oldtimer, Anything over 30 seconds but below two minutes shows that you have a massively ever devolped area of the brain relating to space and movement. Unfortunately this is the same area of the brain that houses ones personality and there's not room for both I'll get my coat.
oldtimer
« Reply #11 on: November 16, 2006, 02:20:40 pm » |
No probelm then... as I am sure many of you have gathered before today I have no personality - just a very large sense of space between my ears!
dks240
« Reply #12 on: November 16, 2006, 02:26:47 pm » |
21.603... so far.
It's not too bad until it starts going really crazy.
« Last Edit: November 17, 2006, 05:14:05 pm by dks240 »
pretzel
« Reply #13 on: November 16, 2006, 03:09:04 pm » |
No better than 14 seconds and completely crosseyed now! Ah well back to work....
Pieter
« Reply #14 on: November 16, 2006, 10:08:52 pm » |
The result also depends on your connection speed. At the office I couldn't do better than 17.7, but at home I easily did 65 seconds. You'd be brilliant with a dial up connection!
