November 23, 2024, 03:34:20 pm *
Author Topic: castrol calendar  (Read 3428 times)
alibongo
« on: June 07, 2006, 12:43:06 am »
Has any body seen the picture of an aston martin on this years calendar, have you noticed  a strange pipe thingamagigy poking verticaly outa the rear of the right hand side of the bonnet ( just behind the vent and about 18" long) does any body know what it is or does?Huh either that or a mechanic has left his idle adjusting gizmo in the orfice !!!
been there done that doing it again !
Chris24
« Reply #1 on: June 07, 2006, 01:03:32 am »
Its a pitot tube, like you would find on aircraft. Its used to provide accurate information as a speedometer.
There you go, theres your answer.
RS2 Babe
« Reply #2 on: June 07, 2006, 01:19:31 am »
 Kiss Kiss Kiss
Having a blonde moment Mr Bongo - glad I knew what of of them is Wink
alibongo
« Reply #3 on: June 07, 2006, 09:26:12 am »
Aaaaaaahhhhhhhh ........it did make me wonder, thats a bit old school innit? what with all the electronics available these days any sat nav will tell them how fast they are going Huh? less drag too !  Cheers
« Reply #4 on: June 07, 2006, 09:48:48 am »
Checkout an F1-car, how many tubes there are still sticking out in front of the driver. It's not only a speedometer, but also measures humidity and airtemperature for the engine.
Christopher
To add speed, just add lightness.
« Reply #5 on: June 07, 2006, 11:21:13 am »
The pitot tube can be used to determine the air flow velocity, pressure, temperature and humidity to calculate the correct density.
As the tube is fitted to the vehicle it will be providing the engineers with real time information to allow alterations to the engine settings.
Le Mans is for the week......not just 24hrs!
When life throws you lemons, bring out the tequila!!
Vodka! Cheaper than Botox and paralyses more muscles!
« Reply #6 on: June 07, 2006, 11:25:46 am »
Aaaaaaahhhhhhhh ........it did make me wonder, thats a bit old school innit? what with all the electronics available these days any sat nav will tell them how fast they are going ?
And what happens when the GPS system goes down (which it sometimes does) or the sats momentarily go out of allignment? Nothing should ever rely on one core system only.
« Reply #7 on: June 07, 2006, 12:09:54 pm »
Also it wil give the cars speed through the air, rather than over the ground, something of prime importance to an aerodynamicyst / setup engineer.
