November 29, 2024, 05:53:21 am *
Pages: 1 2 [3]   Go Down
Author Topic: Pre-Qualifying  (Read 13775 times)
hgb
You don't win Le Mans - you outlast it.
« Reply #30 on: March 15, 2004, 08:15:15 am »
Why is there a fence ? Is that baby such an animal ?  Grin
« Reply #31 on: March 15, 2004, 11:24:01 am »
That's a toughened glass safety window  Shocked
RS2 Babe
« Reply #32 on: March 15, 2004, 02:33:42 pm »
Also me and mrsPM are off to StMalo for the weekend next friday,just to get me in the mood.
PM
Pm and Mrs PM - St Malo is only 25mins from Me & Mr RS2s abode! - when you have done your shopping and stuff you should drop by or we can meet up somewhere.
Let me know your plans and if you have any spare time for a cup of tea!
Mrs RS2 Babe
powermite
« Reply #33 on: March 15, 2004, 05:11:28 pm »
Thanks RS2 ,i'll certainly try to take you up on the offer.
Thanks again
PM
powermite
« Reply #34 on: March 15, 2004, 05:14:24 pm »
The engine should be a beast.Dyno results show 422 BHP and over 400lbs/ft torque from 2500rpm up to 6000rpm
Yummy scrummy!!
PM
« Reply #35 on: March 15, 2004, 05:20:21 pm »
Yummy scrummy!!
PM
At the flywheel I assume.  What do they reckon at the wheels?
powermite
« Reply #36 on: March 15, 2004, 05:39:23 pm »
not sure at the Flywheel.we'll se when its in
PM
« Reply #37 on: March 15, 2004, 05:48:08 pm »
Looks pretty neat PM. I'm afraid I'm not up to much when it comes to US motors - what's it breathing through, is that an injection set up on top? Is 6000 the red-line or the limit? Keeping the lead out of your boot while you run it in could be tricky, you'll be "The Fastest Man in Wales (With a Moustache)" and no mistake once it's spinning.
25% lost to the drivetrain?
powermite
« Reply #38 on: March 15, 2004, 10:49:01 pm »
H,
Ive changed to a six speed manual too so according to this article,i should only lose about 15%.
That would give me a stoill very lovable 358 bhp at the wheels.
I'll get it on the rolling road though once its running well.
this is the article:
But testing rear-wheel horsepower (rwhp -- obviously, front drivers would be measuring fwhp) makes it difficult to convert from what the dyno says to what the manufacturer says. The manufacturer, remember, measures horsepower at the flywheel. All that equipment between the engine and the wheels -- the transmission, driveshaft, differential, and axles -- introduce friction and inertial losses summarized as "powertrain loss" or "parasitic losses". The efficiency of the driveline can greatly affect the amount of the powertrain loss: Ford's AOD transmission, for example, is notoriously inefficient. As a very general rule, rear-wheel horsepower on a manual-transmission car is about 15% less than SAE net, and rear-wheel horsepower on an automatic-transmission car is about 20% less than SAE net.
« Reply #39 on: March 16, 2004, 09:22:17 am »
Sounds a corker PM, let us know how you get on.
There's two sounds guaranteed to bring a smile and raise not only the hairs on the back of your neck. One happens when you're walking towards a race circuit at the beginning of the day and you hear the first crack-crack of a racing motor fire up. The second happens when after many hours of labour getting a re-built engine back into the car it starts up for the first time and sits in there chuntering away. Best of luck!
Pages: 1 2 [3]   Go Up
