November 25, 2024, 02:57:46 am *
Pages: 1 [2] 3   Go Down
Author Topic: Dear Dave...  (Read 23209 times)
Ferrari Spider
« Reply #15 on: May 05, 2004, 07:12:13 pm »
Just to add my tuppence or Lira, cars designed as left hookers without doubt drive and handle better than ones even built in the factory as a RHD.  Only speaking from practical experience, of course.  I'm sure there some very sound reasons why.
This raises an interesting issue with regard to left hookers which are designed and built as such, do they drive any differently on say Italian or British roads?
« Reply #16 on: May 06, 2004, 07:08:22 pm »
I'm at a loss to understand why a LHD car would be better balanced or handle better than a RHD one. Why would it make any difference?
I drove several LHD cars in UK, including my current ride.
My Corvette handles, grips, accelerates and stops just as well in Britain as it does here - why would it be any different?
The only real issue is overtaking on single carriageway roads (just like the run down to LM for 99.9% of British drivers). Even this is a minor problem if you have enough torque to haul ass when the need arises.
« Reply #17 on: May 06, 2004, 07:46:01 pm »
Yes, I must admit I walked away from this one scratching my head. As far as I know the laws of physics are the same on both sides of the car, assuming the weight distribution is the same, then it'll handle the same.
Mind you, after a close call with a scalpel once, I'm very protective of my left bollock, and I can see how in moments of stress my left shoulder might drop first. But surely it's not the same for everyone!?
Paulathedrooler
R.I.P to the Llamma, hello to the Mauri.
« Reply #18 on: May 06, 2004, 09:14:41 pm »
iT ONLY MATTERS IF YOU ARE TURNING LEFT AFTER LEAVING A FRENCH BAR AND MEETING UP WITH A GREAT DUTCHMAN!!!! DID THE FACT THAT THE JAG WAS A RIGHT HOOKER ALTER THE EFFECT OF THE IMPACT.
PXXXXXX
« Reply #19 on: May 06, 2004, 11:52:21 pm »
H, for a man of youre standing  you should have thought about this. Not all engines and engine bays are of equal weight, due to sumps, etc and the different position of the steering rack.
No replies about racks please!!
Oh thanks for the tunes, i have another 7 versions of that 1 tune, all ready for the arrival on MB !!!!
« Reply #20 on: May 07, 2004, 10:30:02 am »
Well, no...
Maybe in pre-Cortina days the designers didn't give it too much thought, but these days any race/sports car designer worth his socks is going to make sure that the battery, alternator, washer bottle, thermidor and colostomy bag don't all end up on the same side of the car. Achieving an equal balance at each wheel must run pretty high up on their priorities at the design stage. (Remember that the Japs are rhd too, and that's not a small market)
I can't believe a car leaves the factory or workshop with a natural tendency to spin in one particular direction. Unlike that tw*t in number 10.
« Reply #21 on: May 07, 2004, 11:21:10 am »
Well, no...
Steady On H. I think The President and the rest of The TW*TS might be a tad upset with you associating them with the *@$% in No. 10.   Grin
« Reply #22 on: May 07, 2004, 02:53:07 pm »
H - I'm sure Robbo is just f**k*ng with us. Can you imagine a road or race car manufacturer shrugging their shoulders and saying, "It's going to handle like sh*t, but there's just no place else to put this bloody steering rack".
Key elements, as I (marginally) understand the science are unsprung weight, weight distribution, centre of gravity, steering castor angle, toe-in/out, suspension compression/rebound/damper rate, rolling resistance, squat/dive and traction control.
Weight distribution - the centre of mass is most often vaunted as the  key criteria (50-50 front to back) however, lateral distribution is a factor and some designers have been quite clever in compensating.
My cars computer compensates for the weight of the driver when solo, by shifting fuel from one tank to the other (not sure it makes a whole lot of difference with a fat twat like me) which is probably more gimmick than function, but it corners flat right up to the point it breaks traction - and even then it stays composed as it crashes.
Front/rear weight distribution is helped by having the transmission in the rear, as opposed to behind the motor (makes the footwells bigger too).
« Reply #23 on: May 07, 2004, 03:18:06 pm »
Blimey Matt, it sounds like your car is a good deal cleverer than most of the people I know. Over the months you have made me re-evaluate my opinions of American sports cars. There is a garage specialising in US cars just a few mile from me, and suddenly, the odd C5s he gets in are starting to look like remarkably good value.
Just to illustrate that us Brits also have a few tricks up our sleeves: Jaguars answer to compensate for the weight of the driver in the racing Mark 2's was to put the battery in the boot, in the diagonally opposite corner, next to the fuel pump...
« Last Edit: May 07, 2004, 05:58:41 pm by BigH » Logged
Mr. Rick
Moderator
Mulsanne on a sunny June Sunday; it's a hard life!
« Reply #24 on: May 07, 2004, 05:46:16 pm »
Just to throw some right-hand/left-hand stuff into the mix, anyone ever noticed that all Porker protos are right-hand drive coming from a left-hand drive country?
908s, 917s, 936s, 956s, 962s and 911 GT1-98s all right-hookers. Even Gilles' compatriots got in on the act with the Renault-Alpine A442s and the Matra-Simcas, the Rondeaus, the list goes on .......................
« Reply #25 on: May 07, 2004, 05:55:15 pm »
Rick,
I recall reading that at some stage in past the ACO rules specified rhd, although I've never been able to confirm this. Why this would be, I'm not sure, but it would explain why most of the protos used to be rhd (and they had to have nominal room for a passenger, and possibly a pig, and six chickens in the back..)
« Last Edit: May 07, 2004, 05:57:30 pm by BigH » Logged
« Reply #26 on: May 07, 2004, 06:00:56 pm »
Blimey Matt, it sounds like your car is a good deal cleverer than most of the people I know. Over the months you have made re-evaluate my opinions of American sports cars. There is a garage specialising in US cars just a few mile from me, and suddenly, the odd C5s he gets in are starting to look like remarkably good value.
I would be kidding you and myself to suggest that American sports cars are all good - I've had a long-standing love affair with yank iron and owned a few down the years. The C5 is without a shread of doubt, the best bang for the buck available anywhere - but is flawed in some respects. The interior is a bit cheap, but equipment levels (head-up display, dual zone climate control, Active ride, ASC, Bose sound system and power everything) compensates. Early C5's had a few teething troubles in terms of build quality - and I expect the C6 will have too, but overall, it is the most capable car I have owned and I have never regretted choosing it.
A lot of people are fazed by expectations of high running costs and depreciation and lack of service back-up. When I ran the car in UK, buying petrol and tyres hurt, but everything else was cheaper than the Audi and Range Rover that preceded it.
Anyone who is after eyeball flattening performance and is in the market for a good spec 3 series BMW (pricewise) and didn't need the rear seats would be foolish not to consider a Corvette - even if it is a bit ostentatious. Anyone who buys a TVR is either seriously mentally retarded, or didn't compare it to a 'Vette.
I know a guy in England who's about to be relocated to New Jersey and has been offered the equivilant of $37,500 for his '98 C5 Coupe. He can replace it with a 2002 Corvette ZO6 and have change. I wish I'd done that with hindsight - the ZO6 is a 405bhp missile.
The current Viper is also very, very good (though more expensive than  C5) and (dare I say it) even a little over-powered. Aside from the exotics (Saleen, Callaway, Mosler and Lingenfelter) mass produced American sports cars are fast, but not particularly good drivers cars - the Ford Mustang Cobra is awful - like sh*t off a shiny shovel in a straight line, but otherwise piss-poor.
Never chop in that Jag, but you should go and have a look at a C5 next time you're passing, they're not to be sniffed at.
« Reply #27 on: May 07, 2004, 06:12:43 pm »
Oi Paula! - watch it!
Ok, I'm not sure the rhd made much difference, unless of course the weight of the 5amp fuse in the radio upset the balance, but it was the airbag that really saved my bacon.
He prefers to be called Uncle Albert, but he'll get used to 'Airbag'.
I know LM's getting close, it's a sign, just like the first swallow of summer (now now), the sight of Albert polishing his rifle and muttering about The Hun means that he suspects a channel crossing is imminent. Personally I always think he's pleasantly surprised when we say we're nearly on the ferry, I'm sure he's genuinely relieved when he realises he's going to have a nice afternoon on the briny and not going to be pushed out of the back of a Lancaster at four thousand feet with false papers.
We're trying to get him to bring his penny farthing this year, that'll be a riot on the way to Arnage alright...
« Reply #28 on: May 10, 2004, 07:46:50 am »
I have said it before but obviously you guys don't remember. Prototype sports cars run on Road Courses
and most of the world's road courses have more right hand turns then left hand turns so positioning the driver on the inside for most turns is favoured.
Road cars are full of compromises and anyway  most drivers would not notice the difference.
Peugeot 404 steering wheel is angled slightly to the right in right hand drive cars.
Renault 5  wheel base is different from left side to right side.
Porsche Boxster has a perfect 50/50 fore and aft balance.
« Reply #29 on: May 10, 2004, 10:49:40 am »
Matt, the garage up the road has just passed the £/L barrier, that's pain alright.
Can any of our French correspondents let us know what the rate is in France? I think I'm going to have to buy a new plastic hose and bottle of mouthwash.
Pages: 1 [2] 3   Go Up
