November 26, 2024, 12:33:37 am *
Author Topic: Tool Guide  (Read 5028 times)
JDS
Moi, enivré? Sűrement que vous me moquez monsieur?
« on: May 14, 2010, 11:47:58 am »
In the runup to LM, those CA'ers that know some of the teams and mechanics may wish to pass on some of the valuable information below:
Motoring tool guides:
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted fender you were repairing.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard earned guitar calluses from fingers in about the time it takes you to say, "YEOWW poo..."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
CUT-OFF SAW: A portable cutting tool used to make metal bar stock too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
DUAL ACTION SANDER: A power sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for ignighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars, trains and motorcycles, they are now used mainly for impersonating that 9/16” or 1/2” socket you've been searching for the last 45 minutes.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity. Also used for shortening fingers.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed new brake pads, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
RADIAL ARM SAW: A large stationary power saw primarily used by most shops to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. It is sometimes used to convert common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 km away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were last over tightened 30 years ago by someone at Ford, and instantly rounds off their heads. It can also be used to contaminate your paint with oil and water.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object you are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. It is especially useful for slicing work clothes, but only whilst you are wearing them.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also, most often, the next tool that you will need.
chop456
Team YFDS
« Reply #1 on: May 14, 2010, 12:37:43 pm »
A screwdriver, when dropped on the ground, can also be used to locate the exact center of the car.
« Last Edit: May 14, 2010, 12:40:30 pm by chop456 » Logged
I stole DelBoy's lighter and lived to tell the tale.
Jaydee
« Reply #2 on: May 15, 2010, 04:15:59 pm »
Must say I agree with all of the above, the rotary wire brush is very good at impaling ones belly through clothing and just leaving a short end protruding just enough to grab with tweezers and remove, also the i'll just hold this bit in my hand and give it a quick wire brush always ends up removing copious amounts of skin and no rust. But how many times do we do it ? surely its not just me. Its very awkward to type when you cant bend your knuckles though lack of skin. only 23 days and counting for the off for me.
« Reply #3 on: May 15, 2010, 06:21:46 pm »
A Hot gas welding wire rods are excellent for self tattoing of your belly though overalls and clothing while adjusting their length Shocked
« Reply #4 on: May 15, 2010, 07:30:03 pm »
Something that is always to hand -
Duct tape, always in my tool kit and normally in the car/cherry picker, it's even NASA engineers and astronauts tool kit!
Also makes a nice wallet - orange of course  Grin
« Reply #5 on: May 16, 2010, 12:12:31 am »
Duct tape, always in my tool kit and normally in the car/cherry picker, it's even NASA engineers and astronauts tool kit!....
As seen on Apollo 13
« Reply #6 on: May 16, 2010, 11:29:15 pm »
somehow the beer bottle used as an improvised hammer is missing Grin
I thank you.
( ........ I'm still wearing the scars!)
« Reply #7 on: May 21, 2010, 01:44:34 am »
Peter, is that improvised or impoverished. The outcome would be the same though.
JDS
« Reply #8 on: May 21, 2010, 09:16:10 am »
Hey, we've built, repaired, anchored down many a tent/gazebo with rolls of the stuff - essential kit agreed. You know the saying "if it moves and should not, use duct tape, if it don't move and should, use WD40"  Grin
