October 06, 2024, 07:26:20 am *
Author Topic: TV - France  (Read 13105 times)
« on: April 30, 2010, 02:34:24 pm »
saw this due in at Aldi
word it work in france?
may help to watch Footie
http://www.aldi.co.uk/uk/html/offers/special_buys3_13988.htm?WT.mc_id=2010-04-30-13-04
Kpy
I'm a Le Manster
« Reply #1 on: April 30, 2010, 04:00:31 pm »
Yes, if it works in UK it will work in France.
But note that it only gives you free to air programmes.
« Reply #2 on: April 30, 2010, 05:17:29 pm »
The dish is a bit small (35cm).  The further south you go, a bigger dish is required.
For LM area, it is recommended that you have a 50cm dish, especially for the channels coming from the Astra 2D satellite which has a very focussed beam (on the UK) - trouble is, I don't know which channels come from which of the three Astra satellites!
It's always a bit of a lottery as to how long it takes to get the dish pointing in the right direction and elevation - especially after a few cold ones!!
clkgtrlm1
Le Mans - Follow the Carbon Footprints!
« Reply #3 on: April 30, 2010, 05:23:05 pm »
Satellite chanels and locations here -
http://www.lyngsat.com/28east.html
Baldrick, my Lord! But I can change it to Ploppy if it'll make things easier.
johnhere
« Reply #4 on: April 30, 2010, 06:40:10 pm »
You will have no problem with this size dish at Le Mans.
Had this size up and running for months at our venue Le Bounty it was from Maplins.
Now replaced with one a bit larger than the ones used in the UK but a lot less than 1m
Just get a clear view to the Sat and set up on the ground the dish does not have to be high up and setting up on the ground is more easy.
But the Sat is very close to 2 others and only need very very fine adjustment to get the correct one.
Next time I am over will get a compass reading for you all
« Last Edit: April 30, 2010, 06:45:27 pm by johnhere » Logged
Jules G
« Reply #5 on: April 30, 2010, 07:09:42 pm »
Neil,
I look forward to watching some racing and footie at your camp site enclosure in June then Wink  Grin Grin Grin
Jules G
« Reply #6 on: April 30, 2010, 11:07:18 pm »
35CM is a bit small for the Dish according to most of the specialist sites.  There is a contour map that shows the signal dropping off once you get into Normandy.  Once you hit the Med you need Jodrell Bank as Sky are so mean.  I'm sure I've heard that standard Sky dishes work, and they're 43 cm.  Depends on the LNB too
Maplin do a similar kit which used to come with a 60 cm dish, and that works well from Blue Nord, but you need a post to bolt it to.  They also do a 39cm dish in a suitcase for camping
Why not take a dvd player instead.  That way there's a chance England might win Grin
And check out Aldis other bargains - garden chairs, parasol lamps, trailer locks etc  They must think summer is here
« Last Edit: April 30, 2010, 11:17:40 pm by Lorry » Logged
« Reply #7 on: May 01, 2010, 12:20:32 pm »
Light blue (inner 'circle') - 50cm dish      Dark blue   60           Green       75 .....etc
« Reply #8 on: May 01, 2010, 12:32:27 pm »
My Sky Mini-dish (53) works fine here.  35... I'd be a bit worried.  Whatever, buy in the UK, this stuff is silly price over here if you're paid in sterling.
« Reply #9 on: May 01, 2010, 11:33:30 pm »
Well found Del.  Termie proves the point again - size matters!
Last year (I'm told) Bricomarche had some deals on Analogue kits, which will pick up Eurosport1
Compared with some of the other aspects of Le Mans (or the new kitchen - AAAAAAAAAAAAAAArgh), this is getting rather simple, and don't forget Kangaroo TV
johnhere
« Reply #10 on: May 03, 2010, 12:07:10 pm »
I can guarantee a 39cm dish (mini dish) will work fine in Le Mans.
As I said before the problem is finding the right satillite as its very close to 2 others. As long as you have a clear view then you should have no problems......clear includes no trees or bushes in the way.
« Reply #11 on: May 03, 2010, 12:52:18 pm »
Dish configuration for finding UK Freesat channels from LM :
Azimuth 144.3
Elevation 28.54
Polarisation Angle -15.48
Eurosport is encryped whether you connect via Freesat or TNT (the French equivalent) so I guess you also need a card or something for other than free-to-air (I get my Eurosport via a Canal + package here.)
Analogue signals are being phased out but I don't know when as I don't have an aerial myself.
« Last Edit: May 03, 2010, 12:57:07 pm by termietermite » Logged
Lord Steve
The only self appointed peer on Maison Blanche!
« Reply #12 on: May 03, 2010, 09:42:56 pm »
You're all very technical. Can't I just find a bar in Olde Le Mans that will show the Enland games? Or better still in Olde Arnage?
« Reply #13 on: May 03, 2010, 11:11:26 pm »
You're all very technical.......
This is nothing compared to the kitchen.  I've just found 2.7metres of cabinet in a 2.6 metre gap.  I thought computers couldn't do that.  Lots of pretty pictures though.
And I hear that analogue Eurosport is good for another few months.  Dish alignment is simple with a compass, unless you've got a magnetic dish like mine.
Brad Zarse
Demi Moore's toy boy
Drinking can be hazardous to your health.....
« Reply #14 on: May 04, 2010, 10:43:57 am »
We've always used a standard Sky Minidish - it's not perfect, as when it really hacks down, the signal will go - but that happens here too.  It takes a while to set up, but isn't actually THAT hard - I think it's normally down to the fact that I'm trying to do it a little worse for wear normally that takes the time Smiley
Having thought long and hard about this though, I am of the opinion, that the best place to watch the football is likely to be at the Tetre Rouge Stella Bar, or the Guiness Bar in the village - SURELY they'll have the game on?
Check out my band!  www.blackmarketband.co.uk
On Facebook:  www.facebook.com/bandblackmarket
See you at a gig soon?
