November 26, 2024, 04:46:59 pm *
Author Topic: Car related Joke  (Read 4843 times)
« on: May 06, 2003, 12:05:46 pm »
There is a monkey in the jungle wandering around when he bumps into a picnic area. He checks it is all safe and then wanders in and finds a 4 point tool (a Fork). He goes rushing back to his jungle friends and shows them all his 4 point tool saying how brilliant it is and how you can eat your food and brush your hair with it.
After several months of using it, it goes missing so he asks all his jungle mates if they have seen it:-
Monkey asks 'Have you seen my four point tool' to the Giraffe.
The Giraffe replies 'no  i havent seen you 4 point tool.
The Monkey then asks the lion 'Have you seen my four point tool'.
The lion replies 'no  i havent seen you 4 point tool.
So the Monkey then asks the jaguar 'Have you seen my four point tool'.
The jaguar replies YES.
So the monkey asks for it back to which the jaguar replies 'I have eaten it'
The monkey says 'WHY' so the jaguar replies:-
WELL I AM A 4 POINT TOOL EATER JAGUAR
(4.2 Litre Jaguar)
Thought it rather funny.
Rick.
« Reply #1 on: May 06, 2003, 11:51:45 pm »
Thought it rather sucked.
(Thanks for the bit in brackets - I'd have never figured it out otherwise)
Ruptured Duck Motorsport
« Reply #2 on: May 07, 2003, 12:10:27 am »
Translation for Haynes Manuals
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips then beat repeatedly with hammer
anticlockwise.
Haynes: This is a snug fit.
Translation: You will skin your knuckles!
Haynes: This is a tight fit.
Translation: Not a hope in hell matey!
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start, now you are looking at scarey photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (catering size).
Haynes: Retain tiny spring...
Translation: "Jeez what was that, it nearly had my eye out"!
Haynes: Press and rotate to remove bulb...
Translation: OK - thats the glass bit off, now fetch some good pliers to dig
out the bayonet part.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead
are throbbing them re-check the manual because this can not be 'lightly'
what you are doing now.
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it!
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating.
Translation: Your Mum could do this... so how did you manage to botch it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low,
tiny, 'ikkle number... but you also thought the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating.
Translation: But Nova's are easy to maintain right... right? So you think
three Nova spanners has got to be like a 'regular car' two spanner job.
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you pleb!
Haynes: Five spanner rating.
Translation: OK - but don't expect us to ride in it afterwards!!!
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahahaha!!!!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at,
throw at the garage wall, then search in the dark corner of the garage for
whilst muttering "bugger" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yep, as I thought, it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark pugs removed.
Translation: However, starting the engine afterwards will be much harder.
Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift...
Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Everyday toolkit
Translation: Ensure you have an RAC Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Haynes: Index
Translation: List of all the things in the book bar the thing you want to
do!
For Added Haynes Fun:
Go to the first section, Safety First, and read the bit about Hydrofluoric
Acid - do you really want the advice of a book that uses this form of
understatement???!!?
Now look at the lovely colour section on body repairs - as you look at these two pages say to yourself over and over until it sinks in "mine will never look like that..."
Flick to the end and look at the colour glow plug pictures, how do these
compare to the glow plugs in your Mini? If you cannot locate the glow plugs in your Mini see the last translation on the list!
FOUND AT http://www.wkac.ac.uk/poster/other/personal/JOKES/car/Haynes.htm
Scarred old slaver know he’s doin’ alright.
« Reply #3 on: May 07, 2003, 08:44:27 pm »
Aaah, the Haynes Manual,
My warmest memory of this publication is when I followed it's advice when stripping a UJ. 'A light tap with a hammer will dismantle the joint'. I tried this and got nowhere. In no time at all, the method had escalated until I was stripped to the waist, taking a 100m screaming run up with a 14lb sledge, and nailing the fecker on the bench.
I ended up melting it into a pool with a torch, that showed the b*stard.
Now, if we could train up some llamas...
