Title: CAMPING AT HOUX Post by: chris on May 14, 2008, 09:35:26 am CAN ANYBODY TELL ME WHAT TYPE OF HOOK UP CONNECTIONS THERE ARE AT HOUX. ARE THEY STANDARD THREE PIN OR TWO PIN. THANKS
Title: Re: CAMPING AT HOUX Post by: Lawnmower Man on May 14, 2008, 10:07:50 am No I can't. But I would ask that you turn off the caps lock. When you have all capitals it looks like you are shouting.
t. Title: Re: CAMPING AT HOUX Post by: Mr. Invincible Mou on May 14, 2008, 08:54:37 pm Sockets are the round two pin type.
(http://img.photobucket.com/albums/v420/bullocks/bits.jpg) As you can see in the above piccie, this is what we used to use for Houx. The orange lead is an external type camping cable with the standard exterior round sockets (one male, one female). You then need a two pin plug with female round socket as seen towards the top of the picture. This is what plugs into the hook-up. And we then use a male round socket to standard UK three pin plug socket into which we plug an RCD. These can be seen at the bottom of the pic. We then plug 4-way extension leads into this. Title: Re: CAMPING AT HOUX Post by: chris on May 15, 2008, 09:53:02 am Thats a help thanks very much
Title: Re: CAMPING AT HOUX Post by: bgeorge104 on May 15, 2008, 10:39:47 am You will also need a very, very long cable.
Title: Re: CAMPING AT HOUX Post by: Piglet on May 15, 2008, 01:45:42 pm You will also need a very, very long cable. a doubler is also useful as there aren't usually enough outlets on the tower so you can unplug someone and plug them and you into a doubler. Duct tape is also useful so that you don't find yourself permanently unplugged... Title: Re: CAMPING AT HOUX Post by: chris on May 22, 2008, 02:07:50 pm Thanks for all your advice
Title: Re: CAMPING AT HOUX Post by: nickliv on May 22, 2008, 02:36:16 pm You will also need a very, very long cable. a doubler is also useful as there aren't usually enough outlets on the tower so you can unplug someone and plug them and you into a doubler. Duct tape is also useful so that you don't find yourself permanently unplugged... Well, duct tape or a couple of bits of exposed copper. |
