Club Arnage => Help => Topic started by: powermite on June 05, 2007, 11:48:10 pm
Title: propshaft balancing
Post by: powermite on June 05, 2007, 11:48:10 pm
any of you guys know somewhere reliable i can get this done?
Cheers
PM
Title: Re: propshaft balancing
Post by: alibongo on June 07, 2007, 12:29:34 am
Yup, there is a place in wimborne dorset, any good to you?
Post by: alibongo on June 07, 2007, 12:32:42 am
If your stuck try putting a jubilee clip on it and rotate till you lose bad vibes dude,
Post by: Canada Phil on June 07, 2007, 04:47:45 am
Hi PM,
        Bit late to discover at this stage. Has it thrown a weight? look for tell tale clean spot. Are the universal joints in good shape sometimes they can cause an out of balace feel too.
See you in Le Mans
Canada
Post by: powermite on June 07, 2007, 09:07:25 am
thanks guys
Ive found a place in Bristol so i'll be taking there this morning.
Phil,if I dont get it sorted ,i,ll go with AJ and Griff will go in with Doubtfire
Either way,we'll be there
cheers
PM
Post by: Andy Zarse on June 07, 2007, 01:17:53 pm
I greased the UJ's on the Commer propshaft the other day and for the first mile or so there was a sort of juddering "out-of-balance" feel to the powertrain. It soon went away, but it's worth remembering this when you install the newly balanced shaft, grease it up, drive off and then start cursing at the poor job the balancing people have done.....
Post by: powermite on June 07, 2007, 04:30:59 pm
i think ive decided not to faff about and get all worked up over it.I think it can stay at home in disgrace while its mates are in LM having fun.That'll teach the b'st'rd
PM
