Club Arnage => General Discussion => Topic started by: smokie on July 10, 2005, 11:59:32 pm
Title: Server outage
Post by: smokie on July 10, 2005, 11:59:32 pm
Apologies for the loss of service. Lennart has been busy. Here's what was going on...
On  top of having a completely new power system installed (with a scheduled downtime of the entire hosting company!) we suffered  a failing memory bank, when we eventually got the power back.
I  switched to the other server - which should have a copy of ev­ erything which is less than 24 hours old. Since I was still playing  with  different  upgrades,  I had NOT enabled database syncronization, so there MIGHT be a  few  entries  missing,  as  the newest  databasedump  I  had  accessible was saturday around 11am (GMT) - but I trust it, the  faithful  members  will  post  their stuff again (if any are affected)
The good news, however, is that the sever is now on a power system which is 100% brand new, and with a UPS  and  (in a  few  weeks) diesel generator with 1 MegaWatt capacity, - so we should NEVER run out of power - even if the power companies  get  more  breakdowns (as it seems to be the standard of the day)
Some posts may have been lost as a result. Once again, apologies.
Title: Re:Server outage
Post by: Robbo SPS on July 11, 2005, 01:01:01 am
retuned home from an ace moment or two at the G8 to find e-mail from smokster about no CA, logged in and it was here, no problems.
Post by: Canada Phil on July 11, 2005, 05:10:48 am
Hey We're Back. Hi Robbo. Thanks Lennart.
I am only about one Million posts behind.
Canada Phil
Post by: Paddy_NL on July 11, 2005, 09:13:00 am
Oh well, as long as nobody moans about loss of number of posts... ;)
Have you guys collaborated with MotorsTV? They were without any commentry for the first two hours yesterday :(
Post by: Andy Zarse on July 11, 2005, 05:07:55 pm
Outage? Outrage more like.  >:(
For one terrifying moment I thought the Modern Commer Replacement thread had gone to the gret recycle bin in the sky. Just lost the last few posts so had slipped down the board a bit. Phew. There's gems in there, gems.  ;)
Post by: mgmark on July 11, 2005, 05:36:06 pm
Gems? - my dear chap - it is a positively inexhaustible diamond mine of essential information.......
Post by: smokie on July 11, 2005, 06:50:22 pm
Seems that some people are receiving errors in some threads.
If you receive an error please copy and paste the error message into this thread and also say which topic and forum the error was seen in.
Lennart will do his best to fix them - but I suspect that an index has got broken in the above turmoil...so they may be unrecoverable.
Thanks
Geoff
Post by: DelBoy on July 11, 2005, 06:59:54 pm
2: mysql_num_rows(): supplied argument is not a valid MySQL result resource
(/home/www/club-arnage.com/html/yabbse/Sources/Display.php ln 159)
Trying to access the 'Silverstone' thread (currently the first tread) in 'Just to say Hi'
Post by: Mr. Invincible Mou on July 11, 2005, 07:17:24 pm
I am also getting
Code: [Select]
in the "you're nicked 2005" thread in the "It Happened To Me" Board.
Post by: Lawnmower Man on July 11, 2005, 10:13:02 pm
I see this error too.
Post by: Paddy_NL on July 11, 2005, 10:28:28 pm
same here
Post by: Perdu on July 11, 2005, 10:50:21 pm
Phew...
I thought I had broken it by dumping a load of cakes or biscuits or whatever you compooter guys calls 'em.....
 :o
Glad it wasn't me and even gladder to be back in with the gang again..... I was getting lonely out here in Outer Mongolia (OK, Streetly almost the same thing!)
 :D
bill
Post by: garystout on July 12, 2005, 12:43:44 am
Not having gone this year, (i might have mentioned this before) i was deeply  concerned at the down time , please dont let this happen again as i need my fix of Club Arnage to help me through the day
Gary
Post by: DJet on July 12, 2005, 01:12:59 am
You can relax garystout , we now have the capability of running on dual power-sources, one of which is with UPS and a 1 MegaWatt generator.
There are 8 (eight) powercables straight from a dedicated 10 kV transformer, each about as thich as an arm, - and rated at 250Amps (at 380 Volts) - so power is NOT running out.
Half of them power the cooling system (makes sense, as the other half produces the heat :-) )
Whats even better is that the entire building is now on this system, - so even the coffee machine will work, if the powergrid drops out - important stuff, ehh?
I believe the small errors we see, has to do with the database being copied  from one machine to the other, - so new posts refer to no no longer existing entires.
But please keep posting the errors in ths thread, so we (I) can track them.
-- Lennart aka Djet,   serveradmin
Post by: smokie on July 12, 2005, 08:55:34 am
Hi Lennart. I've come to a conclusion. The thread with the newest post in Just to Say Hi forum will always crash when you try to open it.
I set up a thread called Test and it couldn't be read. But I could read the threads which had previously had a problem. So I added a post to the Dark Warrior thread and the test thread then worked OK, but the Dark Warrior didn't.
UPDATE: Not so sure the theory was quite right, but I've managed to start a Junk thread which I can't delete cos it has the problem. It definitely seems that only one thread is unreadable at a time, and this is the latest to be updated. I'll leave it to Lennart...
Post by: DelBoy on July 12, 2005, 10:53:58 am
Same error in 'It Happened to Me' Forum.
Post by: Perdu on July 12, 2005, 10:46:25 pm
First thread in "It Happened to Me"
(/home/www/club-arnage.com/html/forum/Sources/Display.php ln 159)
Not awfully worried about Porker threads unless Steve McQueen is driving 'em but no doubt someone is concerned...
bill
Post by: smokie on July 12, 2005, 10:56:34 pm
Lennart has mailed me to say that the Yabbse software which this forum runs on is out of date and no longer supported.
So he is going to upgrade the software. While he is confident that this will not be too difficult, it will mean some more down time. He is expecting to be attempting this tomorrow morning (Wednesday).
I'm not sure that the appearance will change much, nor the functionality. The new product was developed by those who developed this product so externally much is the same.
However you may find you need to re-bookmark any direct links to the forum as the address has changed.
Post by: Perdu on July 12, 2005, 11:06:37 pm
Gonna be "oops, heads down" tomorrow then. Thanks for the warning Smokie
I won't try bookmarking 'til I find the new site then, is that it?
